Info on Carbs and inlet Manifold ?????
Posted: Wed Aug 19, 2015 3:26 pm
by STG95F
Can anyone tell me what these carbs and inlet are , apart from 1"1/4s . more whats the inlet is it a home made type do you think ??
Re: Info on Carbs and inlet Manifold ?????
Posted: Wed Aug 19, 2015 4:06 pm
Inlet doesn't look home made to me.
There were a lot of people using tubular steel manifolds back in the 60's the most notable being Downton.
But there were others; Longman, Janspeed & Derrington to name a few.
Posted: Wed Aug 19, 2015 4:18 pm
by swifty
Looks like a maniflow with a servo take off added at later point . .... Ken
by STG95F
Is there anyway of telling what make the manifold is ? I can't see and makers marking numbers etc ?
Posted: Wed Aug 19, 2015 4:20 pm
by STG95F
Ken , that may make sense with the exhaust that came with it all ( bottom cut off ?)
Posted: Wed Aug 19, 2015 5:32 pm
by Cheeser
If it is a manifold from the '60s then could be Downton, Janspeed,derrington or other,but not Maniflow or Longman they hadn't left Downton at that stage.
Posted: Wed Aug 19, 2015 5:48 pm
by ivor badger 2
If you look closely, you will probably find it has not been cut off and made that way. That's because it was made for an 1100 and not a mini.
Posted: Wed Aug 19, 2015 6:11 pm
by STG95F
The chap i got it off said his brother had it on his Mk2 S ? But who knows
We will never know
Will stick them on Ebay and see what they make
Thanks Ian
