Switch panel hole
Posted: Tue Jul 07, 2015 7:54 pm
by alex-95
I'm going to fit a mk1 switch panel to my '82 mini, So I'm going to weld in a plate into the dashrail. Would anyone be able to take a photo of theirs with a ruler across it so I can get the dimensions and to print it out to scale?
Re: Switch panel hole
Posted: Tue Jul 07, 2015 11:11 pm
by 1071bob
Here you go, the 32mm dimension varies a bit along the slot. I'm sure M-Machine do a panel to do this.
Posted: Thu Jul 09, 2015 11:19 pm
by alex-95
1071bob wrote:Here you go, the 32mm dimension varies a bit along the slot. I'm sure M-Machine do a panel to do this.
Cheers Bob, found the panel on m-machine, will look at making one first.
