Brake proportioning valve
Posted: Tue Jul 07, 2015 7:01 pm
After spinning my Mk1 twice (the first time into a hedge) under heavy braking, and mostly recently over the weekend, it dawned on me that twice must be more than just bad luck.
Quite easy to diagnose..the PO has removed the proportioning valve and fitted a plain tee piece
The first time it happened I thought it was just over exuberance/inexperience (and, ahem, being out with an Integrale and a Mk1 and Mk2 Escort
) but now all is revealed! (and I feel less of a plonker, but I should have checked it out after the first incident - which cost me a new front end and sub frame)
I presume the solution is to fit a Minispares adjustable valve?
..check your valves out there and go easy!!
Jon
Jon
