Hello All,
I am looking for help in finding the correct and original material for the
Hydrolastic Sleeve Protectors, part # 21A1582
Most of the usual parts suppliers do not list this part !
What material are you finding is as close as possible to the original factory
installation? The photos I have seen on this site show it as a green foam
material that is wrapped around the hydrolastic pipe at five points on each side.
Thanks,
Jim
Hydrolastic Sleeve Protection, Part # 21A1582 ?
- Has thanked: 206 times
- Been thanked: 80 times
Re: Hydrolastic Sleeve Protection, Part # 21A1582 ?
As I recall it's just a plastic sleeving a bit like Spriro-wrap only wider.
Here you go
http://www.somerfordmini.co.uk/eshop/in ... ts_id=3261
Here you go
I'd agree with Spider, it is a green plastic sleeving, cut spirally and wrapped round.
I'd have thought green water tubing would do the job just fine.
I did order the 21A1582 from Somerford. What I received was very thin BLACK "shrink wrap" like tubing. I was hoping for the green wrap material that I have seen in photos the original cars.
I'll keep looking locally for a green pipe wrap.
Jim
Jim
Something like this isn't too far off
http://www.ebay.co.uk/itm/FLEXIBLE-GREE ... 27debc6a79
Try your local aquatics centre maybe ?
- rich@minispares.com
the 1/2" stuff would be ideal!Andrew1967 wrote:Something like this isn't too far off
Just to be clear.
Was the original factory part made of PLASTIC tubing or a FOAM wrap material
Jim
Jim
