Twin cable handbrake & rear subframe
m1cH1
Post by m1cH1 »
Hi together!
There´s one thing I´ve thought about for quite some time and haven´t found an answer so far...
Can a twin cable handbrake be used in conjunction with a later rear subframe from a mini with single cable handbrake? Or has it to be modified in any way?
Cheers, Mike
ivor badger 2
Re: Twin cable handbrake & rear subframe
Post by ivor badger 2 »
Just the same, use the correct cables for your car, with lots of grease in the cable slides.
m1cH1
Post by m1cH1 »
Thanks for the fast reply! That´s just the answer I hoped for!
Then I can use the subframe I have without getting into any trouble during assembly... ;) :D
Cheers, Mike
