Cooper 998 mk1 spaced drums
Hi everybody
I'm colecting some missing parts to rebuild my 1966 cooper mk1 and i have some questions:
the spaced drums are the same size as cooper s and 1275gt ones or smaller?
if smaller, how big?
thanks in advance.
thanks in advance.
Re: Cooper 998 mk1 spaced drums
Same diameter obviously but the spacer is thinner, the metro rears look very similar to the Cooper ones and might be easier to find.
- coopertim
- Location: In the garage spending far more time and money than my wife agreed to! Lincolnshire UK
- Has thanked: 27 times
Sorry to add to the thread but I'm wanting to put my 'S' wheels on my new 850. Which drums will I need and what length studs?
Thanks. Tim
Thanks. Tim
- sandman
The spacer is thinner and incase you are wondering - it's not possible to modify an S drum to same thickness - you'll end up with a big hole.
I have some i might sell...
Cheers,
Ed_
Ed_
- Has thanked: 125 times
- Been thanked: 34 times
You could get a hold of some Aust drums as fitted from about 74 on to the Mini S, SS and LS Range. There are dimensionally the same as the Cooper S Drum, but the spacer is solid, so can be machined down to what ever thickness you like
S Drums with 55 mm studs (P/N 12A1278).coopertim wrote:Sorry to add to the thread but I'm wanting to put my 'S' wheels on my new 850. Which drums will I need and what length studs?
Thanks. Tim
- Vegard
You're thinking of the Superfins. On those you'll end up with four holessandman wrote:The spacer is thinner and incase you are wondering - it's not possible to modify an S drum to same thickness - you'll end up with a big hole.
The original iron drums can easily be turned down.
I wouldn't try it on my original 63 S drums ... the spacer is definitely hollow...
Cheers, Ian
Cheers, Ian
i have a pair of late mk 2 cooper drums, with medium sized spacer, recently re-finished, surplus to requirement and so potentially for sale, complete with studs!
see pictures below. They are in good condition. Let me know if you are interested and i'll get some photos of the wearing surface.
- rich@minispares.com
21A1278...........................
three hours reading a parts book as punishment for you!
- spoon.450
Nice....evonaut wrote:i have a pair of late mk 2 cooper drums, with medium sized spacer, recently re-finished, surplus to requirement and so potentially for sale, complete with studs!
Oiii,,,,,, take that up with the management,,,,,, hims taken away the edit post function.,,,,,,,,,rich@minispares.com wrote:ahem!Spider wrote:
three hours reading a parts book as punishment for you!![]()
