Hydro bumpstops
Posted: Mon Apr 20, 2015 7:37 pm
by Dr S
So they should be fitted with the cone bit at the top and the small hole at the bottom.
There is clearly an art to this. Any ideas, boiling water and fairy is nowhere even close..
Re: Hydro bumpstops
Posted: Mon Apr 20, 2015 9:33 pm
by 5portsrock
Ive used back to black panel spray. It has a silicon content.
Re: Hydro bumpstops
Posted: Mon Apr 20, 2015 10:08 pm
by Dr S
Will they then twist in by hand or is it brackets off the car and vice / press time?
Re: Hydro bumpstops
Posted: Tue Apr 21, 2015 5:38 am
You referring to Competition ones?
The Small Hole goes over the steel knob. I use rubber grease to get them on, no issues. I think you'd have a hell of a time trying it dry.
Re: Hydro bumpstops
Posted: Tue Apr 21, 2015 8:52 am
by Dr S
Cheers chaps, grease ordered, one step closer to blyton!
Re: Hydro bumpstops
Posted: Sat May 09, 2015 7:38 pm
by Dr S
Used silicon spray and popped them straight on. Astonishing stuff. Cheers guys
Re: Hydro bumpstops
Posted: Mon May 11, 2015 8:55 am
by 66S
I ended up adding a nylon plug down the hole to add some more resistance to the front bump stops. The car is almost on the bump stops sitting free.
Regards
