minitravellerman
Posts: 1041 Joined: Fri Oct 08, 2010 3:57 pm
Post
by minitravellerman » Mon Apr 13, 2015 10:05 am
I'm trying to fine tune my rally Mini following some upgrade work so wondering what carb needle and spring would be best for my spec. Maybe someone can help
The motor is a 998 A+ with 12G295 polished and ported head (unskimmed), and Minispares stage 1 kit. Carb is a single HS4.
Any idea what needle and spring spec would be best?
Ian Campbell
Spitz
Posts: 585 Joined: Thu Jun 24, 2010 5:37 pm
Post
by Spitz » Mon Apr 13, 2015 5:32 pm
If you've not skimmed the head your CR is going to be pretty darned low ....unless you're using D top pistons that is.
As for needle, I have a similar setup and I'm running an AAU needle ( but my 295 head is skimmed )
The combustion chamber of the 295 is a lot larger volume than a stock 998 head....that's the reason skimming is needed.
carbon
Posts: 518 Joined: Fri Jan 07, 2011 8:26 pm
Post
by carbon » Mon Apr 20, 2015 6:45 pm
Used to run an old 998 (dished pistons) with 295 head, but it had been well skimmed.
The best spring to start with for HS4 is red. Can't be much help with the needle as this was custom modified by Aldon when they set it up on the RR.
