Has anyone done this switch and if so:
A - What is required to do it?
B - Are you happy with the results?
Thanks for your replies.
Cheers,
Andrew
Assuming you have the Cooper 998 brakes... The majority of 997 cars had smaller padsVegard wrote:If you fit proper pads to a 7" system, they WILL BE adequate for a roadgoing small bore Mini. I've just had a friend of mine race a 998 Cooper, and that works adequatly.
Yes, 7,5"s are better no doubt, but 8,4" with four piston calipers are even better.
Where do you draw the line?
I've been running the 5/8 bore master cylinder with a standard S disc set up. For about 20 years with a fast road 1275.LMM76C wrote:Master cylinder change to S is essential. Without it the pedal will not be just "long" but will hit the floor before it gets round to working at all.
I didn't have any problems with the standard master cylinder set up either on my purely road use only car. I did buy one of those plastic reservoir extenders but never fitted it (mainly because I mislaid itcarbon wrote:I've been running the 5/8 bore master cylinder with a standard S disc set up. For about 20 years with a fast road 1275.LMM76C wrote:Master cylinder change to S is essential. Without it the pedal will not be just "long" but will hit the floor before it gets round to working at all.
Never had any problems with excessive brake pedal travel. Gives good weight to brake pedal, and I don't need a servo.
The only minor downside is that the fluid reservoir is the smaller version, not the taller S type. But this is not a problem for car being used just on the road.
Here's a picture of the my Mk2 998 Cooper standard master cylinder in question. You are of course right that it should have the correct large reservoir (and I wouldn't recommend it to anyone), it's just that a non servo S set up can be used with a standard sized can.LMM76C wrote:You must be talking about a different item. The larger S m/cyl was essential in period - which is why BMC fitted it as standard....
