Hi Folks,
Apparently A35 vans were available with an in-line 850cc engine. Anyone know anything about these engines? is spec' as per early Minis?
The block is clearly marked with a cast in '850' in the usual place where the larger ones have '950'
Al
850cc in-line engine
- mini63
Re: 850cc in-line engine
quick check suggests originally 948cc then back to offering either option 848cc or 1098cc to end of production.
Probably wouldnt have bothered James Hunt much....
- 850man
I have a complete one that is in an A30 doner car I own.
61 Morris 850s here in Australia had the same block drillings as the rear wheel drive engines. (threaded oil pick up hole & rear main upper casting holes) The "850" is in a different position that normal as well.
- Has thanked: 206 times
- Been thanked: 79 times
Is it just the angle of the photo or is that an ultra thin flange block too?
