Carpet fitting
Carpet fitting
I am nearing completion on my mk1 deluxe resto and now have newton carpets to fit, anyone have any advice or info on how to trim around the gear lever it's the magic wand type as it's a 1962 car. Any advice on this would be appreciated as I don't really want to do it be trial and error.
- Nick W
Re: Carpet fitting
I would remove gear lever , fit carpet , then you should be able to find the hole to make a small hole
Then re,fit over gear lever ,to check
I once made a right cock up of the remote hole by not having the side press studs in place first . Luckily newton comercial will sell you a replacement front carpet if you mess up
Up North in Sheffield
- minidean
Re: Carpet fitting
Agreed, thats what I did with mine.Nick W wrote:I would remove gear lever , fit carpet , then you should be able to find the hole to make a small hole
viewtopic.php?f=6&t=8288&start=70
UPR 65 1963 MK1 Super Deluxe
FTX 217K 1971 MK3 Cooper S
- minidean
Re: Carpet fitting
minidean wrote:Agreed, thats what I did with mine.Nick W wrote:I would remove gear lever , fit carpet , then you should be able to find the hole to make a small hole
you can see here?
Re: Carpet fitting
Thanks the picture helps, will have a go at it next weekend as been to practical classics show so not had time to mess this weekend,
