Throttle spindle play on SU's
rolesyboy
Has thanked: 8 times
Post by rolesyboy »
Hi All. I have a pair of SUs I am just rebuilding with a kit from Burlen. I have a very small amount of play in the throttle spindle if I wiggle it in the carb body. Would anybody be able to indicate what is deemed acceptable? When you rotate the butterfly to the open position there is a mm of movement side to side although I reckon this is fine. Cheers. Mark
Has thanked: 125 times
Been thanked: 34 times
Re: Throttle spindle play on SU's
The Axial (side to side) movent you describe is fine, what you don't want is Radial (up and down) movement.
rolesyboy
Post by rolesyboy »
Thanks Spider. Well that means I need to get them rebushed. What is involved? Can any machine shop do this or does it need a specific set up?? Cheers. Mark
swifty
Been thanked: 12 times
Post by swifty »
Mark I've just rebuilt a set with a burlen kit supplied by minispares and it came with two oversized little bushes in the kit just incase you need to re-sleeve the spindle ...... Mine didn't need need to be re- sleeved so I have the bushes still if you need some . ..... All the best your favorite ken in the world ...
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
rolesyboy
Post by rolesyboy »
Cheers Ken. I have the bushes but haven't got the faintest idea of who/how to fit the b'strds. Trying to avoid sending them to Burlen if possible as want them done ASAP.
Thanks for the offer. And yes you're my favourite... :lol:
1071bob
Been thanked: 38 times
Post by 1071bob »
You have the drill out the bodies to take the spindle bush, best done on a mill for accuracy. Make sure you drill just deep enough to take the bushes from each side of the body, don't drill all the way through the body or you'll end up with a high tickover as the air rushes around the gap at the end of the bush! happens a lot according to the guy at Burlens.
rolesyboy
Post by rolesyboy »
Thanks for the advice Bob. Are the bushes regarded press fit? Do they need reaming afterwards??
I haven't got the foggiest idea and need to communicate this with the machine shop. (I am fairly certain that i would have ended up with them drilled right through had you not mentioned that so thanks)
1071bob
Post by 1071bob »
Here is the Burlen technical info:-
http://sucarb.co.uk/technical-h-type-ca ... nd-brushes
The bushes don't need reaming.
