Chewie Baker
Post
by Chewie Baker »
at first i thought it was an Austin Cooper grille, but on closer inspection not enough slats and the gap for the bonnet release is wrong
can anyone identify please?
mk1coopers
Post
by mk1coopers »
Could be one someone made up for a Sprint if it's smaller?
rich@minispares.com
Post
by rich@minispares.com »
its one of those aftermarket grilles that you could get in the 1980's
there should be two angles bits on the bonnet opening hole
they look quite like one of the innocentie grills I think as well?
rich@minispares.com
Post
mk1coopers wrote:Could be one someone made up for a Sprint if it's smaller?
a correctly built sprint has a normal size grill and moustache
if you have to cut either of them down, well, you've fu*ked up with your measuring/cutting!
(see the one that's always for sale as a bare white shell as an example!)
jay weinstein
Post
by jay weinstein »
I've got two nos innocenti grills which are the same as yours except top slat is one piece with a curve in it for the hood latch.
Chewie Baker
Post
by Chewie Baker »
thanks for replies chaps
looking at the John Parnell book it is indeed the same as a mk1 Innocenti grille with a bit missing from the top slat
I'm no expert but don't think its original as according to 'the bible' the innocenti grilles were stainless steel
will clean it up and throw it on ebay
cheers
Martin
