Swiftune distributor
Nick W
Post by Nick W »
I'm fitting a Swiftune dsi , and wondered if the white and black wire from the wiring loom needs to be left on the coil or not . Swiftune insructions says fit red from dsi to + black to - . I think this makes the white and black from the loom redundant ?...Nick
Up North in Sheffield
ianh1968
Re: Swiftune distributor
Post by ianh1968 »
Nick W wrote:I think this makes the white and black from the loom redundant ?...Nick
... white/black also will feed your tacho!
The white/black between the distributor and the coil will be redundant,
but if you have a tacho, the white/black that parallels with the coil -
still needs to be present.
Ian
