Clutch Bleeding and Gearbox
Posted: Sun Mar 15, 2015 10:21 am
hi everyone id first like to say this is going to sound a little strange but if you could help me or give me some tips that would be great.
I;ve just recently installed a new 850 engine into my super coming along well but im having some problems bleeding the clutch. i managed to get a little bit of feeling out of the peddle when i adjusted the arm but the screw is quite far out.
when i push the peddle the arm is moving just there feels like there is no pressure on the peddle.
also the gear box was very strange after i managed to get at least some movement in the clutch i tried to move the car forward when i was checking the gears i found out that in reverse gear the gear stick is still able to go upwards! feels like it has a 5th gear.
i was just wondering have i mabe put the gear lever back incorrectly and accidentally put the gear stick in when it was in neutral ?
again sounds weird but i can take a video if it helps
Thank you
Thank you
