Fibreglass Bonnet Repair
Posted: Tue Mar 10, 2015 9:24 pm
by tomkidd
Now then folks
My bonnet has cracked on the lip of the back of the bonnet (underneath wind screen) and also half way along one of the wings...
Has anyone successfully repaired their own using fibreglass? I was thinking of setting in some aluminium angle strips into it but wondered if it was over kill?
Re: Fibreglass Bonnet Repair
Posted: Wed Mar 11, 2015 7:24 am
by Cheeser
I would have thought that you would be better trying to form a small (mini?
)box section using cardboard or expanded foam as a former rather than metal......provided you've got the space.
Posted: Wed Mar 11, 2015 12:41 pm
by Nick W
Are you trying to avoid painting.if not why not mig weld it ,putting a small metal plate at the back..remove bonnet and take to a body shop if you don't have a mig .I recon its a £25 job ,unless in London then£250
Posted: Wed Mar 11, 2015 12:57 pm
by rich@minispares.com
Nick W wrote:Are you trying to avoid painting.if not why not mig weld it ,putting a small metal plate at the back..remove bonnet and take to a body shop if you don't have a mig .I recon its a £25 job ,unless in London then£250
id love to see a mig welded repair on a fibre glass bonnet..............
Posted: Wed Mar 11, 2015 2:31 pm
by Nick W
rich@minispares.com wrote:Nick W wrote:Are you trying to avoid painting.if not why not mig weld it ,putting a small metal plate at the back..remove bonnet and take to a body shop if you don't have a mig .I recon its a £25 job ,unless in London then£250
I pesumed it was a steel bonnet
Posted: Wed Mar 11, 2015 3:33 pm
by Nick W
Nick W wrote:rich@minispares.com wrote:Nick W wrote:Are you trying to avoid painting.if not why not mig weld it ,putting a small metal plate at the back..remove bonnet and take to a body shop if you don't have a mig .I recon its a £25 job ,unless in London then£250
Mind you I did once set fire to a plastic pig
Posted: Wed Mar 11, 2015 4:27 pm
by goff
