850 Thrust Washers
Posted: Mon Mar 09, 2015 11:12 am
by gs.davies
I'm in the process of rebuilding my engine and swapping the crank from the early small tail with a wet primary gear to a later one with a dry primary gear.
There was noticeable slack in the thrusts in the original crank and in the engine I've robbed the crank from, LOTS of slack.. Looking this morning it seems that oversize thrust washers are obsolete.
How do people get round this with 850s? Or is the case for the 1098 building?
Re: 850 Thrust Washers
Posted: Mon Mar 09, 2015 11:55 am
You can get thin sheets of shim steel & cut out shims the shape of the thrust washer with a pair of scissors if all else fails.
http://uk.rs-online.com/web/p/product/4 ... Atlj8P8HAQ
Posted: Mon Mar 09, 2015 6:24 pm
Drop me a PM.
I can still get them in STD, +0.005", +0.010", 0.015" & 0.030"
Posted: Mon Mar 09, 2015 8:41 pm
by Tupers
Are these the early thin type thrust washers?
When I was looking for a set last year I found a few Morris Minor specialist selling them in standard and plus sizes.
Posted: Thu Mar 12, 2015 8:59 am
If Thornton's don't have them, they don't exist.
http://www.fwthornton.co.uk/
