Y-piece clamps
tomkidd
Y-piece clamps
Post by tomkidd »
Hi folks,
When taking the engine out last week I spotted that one of the square shouldered bolts that go through the clamp on the Y-piece had got bent and thus it threaded when I took it off.
Can I buy just the bolts anywhere as they make it easy with the car being so low as I don't need to get anything on the other side.
Ta!
Re: Y-piece clamps
Contact Maniflow direct, I am sure they will stick you a couple in the post.
Smiffy
Re: Y-piece clamps
Post by Smiffy »
Better with some stainless 'Mikalor' clamps, better than the 'shite' ones supplied with the manifolds.
rich@minispares.com
Re: Y-piece clamps
Post by rich@minispares.com »
Smiffy wrote:Better with some stainless 'Mikalor' clamps, better than the 'shite' ones supplied with the manifolds.
can you nip them up hard enough to clamp the y onto the down pipes though?
I thought they where just posh jubilee clips?
swifty
Been thanked: 39 times
Re: Y-piece clamps
Post by swifty »
That's what I use now . So much better than those with the bolt . Don't tell the cooper S police .... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Smiffy
Re: Y-piece clamps
Post by Smiffy »
As above mine have bolted up tight enough, the supplied mild steel efforts just bend/strench and bottom out anyway.
tomkidd
Re: Y-piece clamps
Post by tomkidd »
swifty wrote:That's what I use now . So much better than those with the bolt . Don't tell the cooper S police .... Ken
That seems tidy, what size are yours?
Dean
Re: Y-piece clamps
Post by Dean »
i got the same for my exhaust you can get w2 and w4.
w4 is all stainless inc bolt
w2 is only the strap that stainless
i got mine off ebay. you can also undo the bolt and they fold open to remove them easier
GraemeC
Re: Y-piece clamps
Post by GraemeC »
They have quite limited size range Tom, you'd be best measuring your pipes.
The ones in Swiftys photo look like 40-43mm - you can get more than that 3mm range from them, but not much!
swifty
Re: Y-piece clamps
Post by swifty »
I will have a look in the morning . I also use these on the other end of the Y piece .... Ken
Porsche 997 turbo S
I am from Essex
rich@minispares.com
Re: Y-piece clamps
They do look quite sturdy and tidy
Nice find!
ianh1968
Re: Y-piece clamps
Post by ianh1968 »
Watch out when buying stainless steel clamps, some have shitty/flimsy
mild steel ferrules in them...
This is where I get mine - They look the same as Swifty's:
http://www.carbuildersolutions.com/uk/s ... eel+clamps
The smaller sizes have an M6 bolt and the larger ones are M8. The ferrules are
made from solid bar and they are 100% stainless. They are stamped "INOX W5".
Being an "Official Wanker", I file the writing off the bolt heads and buff them up to
a mirror finish. They look really nice when you're standing in front of the car...
For a large bore Maniflow, the two Y-Piece clamps are 44-47.
As GraemeC says, get the right size as any diameter error will be multiplied by "pi".
For example, to crush up 3mm, this will equate to a 10mm gap reduction between
the ferrules. (Approximately)...
Ian
rich@minispares.com
Re: Y-piece clamps
im a little worried about smithy......
who claims he is a 'Official Wanker Spotter'
does this mean he enjoys watching men masturbate???????
:lol: :lol: :lol: :lol: :lol: :lol:
tomkidd
Re: Y-piece clamps
Post by tomkidd »
Cheers!
I actually have 2 further down the exhaust but used what came with manifold as it was new
Re: Y-piece clamps
I have asked Smiffy to remove his "interesting" Signature.
swifty
Re: Y-piece clamps
Post by swifty »
Tom I use 40 to 43 and 47to 51 .... Ken
Porsche 997 turbo S
I am from Essex
tomkidd
Re: Y-piece clamps
Post by tomkidd »
swifty wrote:Tom I use 40 to 43 and 47to 51 .... Ken
Cheers, I am running a stage II maniflow manifold so I presume the bigger ones would be best... I'll measure it tonight anyway
1071 S
Re: Y-piece clamps
Post by 1071 S »
mk1 wrote:I have asked Smiffy to remove his "interesting" Signature.
Why?.... Its a respectable term. It must be... the head Chaplain of the US Air Farce once commenced Grace at as very high level dinner with the words "Lord, help us not to be wankers ....." :shock:
Apparently he'd overheard a certain son of transported convicts using the term and on querying the meaning had been told that the term was used to describe individuals who "...over-indulged in self gratification ". He thought this was something better avoided.....
Cheers, Ian
Re: Y-piece clamps
:lol:
Smiffy
Re: Y-piece clamps
Post by Smiffy »
Right changed the signature, knew I should of put unofficial, mind you would still of upset the deniers amongst us.
Locked
