Steering wheel restoration
Posted: Sat Nov 13, 2010 8:06 pm
by rolesyboy
Does anybody know how to restore a standard 'bus' sterring wheel from a Mk1 Mini. Mine has a couple of splits(?) in it above where the spokes join. I was thinking some stopper and paint in gloss black or is that too simple? Cheers. Mark
Re: Steering wheel restoration
Posted: Mon Nov 15, 2010 8:53 am
Easy, plastic padding or any other filler for the cracks. Work it in & rub down. Then give the wheel a few layers of Halfords acrylic black gloss, allow to dry thoroiughly, rub down & repeat the process about 5 or 6 times. You will end up with what looks like a brand new wheel.
Posted: Mon Nov 15, 2010 8:56 am
by rolesyboy
Plastic Padding... Cor, I haven't heard or smelt that for years. Thanks Mark. I was just wondering if the paint would rub off too easily.
Posted: Mon Nov 15, 2010 9:02 am
I have had very good results using the Halfords gloss black. But the thicker the better.
Posted: Tue Nov 16, 2010 10:12 am
by Matty
I need to give my steering wheel a bit of a refresh, but Im concerned about the paint chipping off after its painted?
Do you need to apply a primer before painting?
Posted: Tue Nov 16, 2010 10:26 am
I dont use a primer on steering wheels, as I said above, I rub down with fine W&D (about 400 grit) paint, allow to dry, rub down again & build layers up like that, finishing with 1200 or finer. Chipping has never been a problem, but then I don't wear rings, knuckle dusters etc when I'm driving.
Posted: Tue Nov 16, 2010 11:03 am
by Matty
Ah fair enough i'll give that a go, and just remember to take the knuckle dusters off before driving the mini. :D
