Mk1/2 door hinges - which is which?
- mini5967
Howdy all, got a set of NOS Mk1/2 door hinges that came into my possession a while back as part of a job lot, and which I'm hoping to use during the resto of my '64 850, but I'm trying to work out which ones go exactly where; as I don't have a parts book to hand, I thought I'd throw it out there to you all. I've got 5 of them, and I'm presuming that the numbers stamped at the end furthest away from the engine bay are the key to where they go - I have a 13, 14, 15 and 2 x 16. Hope that all makes sense - over to you folks…
If you're alone and you got the shakes/So have I baby and I got what it takes/Raw Power is sure to come a running to you!
Re: Mk1/2 door hinges - which is which?
Nos stamped near the hinge pin and 1 2 os top 3 4 ns top 5 6os bottom 7 8 ns bottom and you should
have angled spacers to allow for the curve of the door panel
Ian
Ian
- mini5967
Is one number stamped on the A panel side, and the other on the door side? If that's the case, then they're all 7 8 ones - bugger! Thanks anyway - at least I can use one, keep one as a spare, and try and flog/trade/swap the others…
Yes each part individually stamped 1 2 and 3 4 have a noticeable angle for the top of the door
here you go....
Here's what cam with early MK1 (Jan 60)
