Body Dimensions
Posted: Thu Jan 22, 2015 9:28 pm
by 62Morris_Cooper
Hi all,
I think the drivers side may have been jacked out at some point. I just need a bit of a sanity check before I start welding bits in place.
Can anyone please provide the dimensions between the top most seat belt mounting points on a mk1/2 shell?
Thanks in advance
Re: Body Dimensions
Posted: Fri Jan 23, 2015 11:25 am
by woodypup59
I make it 41" side to side, at the higher mount position, ie ~2" down from the cant rail.
Re: Body Dimensions
Posted: Fri Jan 23, 2015 1:39 pm
by 62Morris_Cooper
Excellent thank you very much!
Re: Body Dimensions
Posted: Fri Jan 23, 2015 3:52 pm
by NicholasUpton
My body jig used to pickup the seatbelt mounts but after using it on 7/8 cars I noticed that depending on the car it could be tight, or loose and was not referenced to anything else I was attaching to. So use the measurement as a guide not an absolute. Best bet it to measure the seam that runs across the bottom of the door opening, as it will tell you if the boxed sill section has been damaged/ twisted.
Re: Body Dimensions
Posted: Fri Jan 23, 2015 4:46 pm
by 62Morris_Cooper
I have 41 1/4
But will measure the seam at the floor over the weekend, I think it's somewhere near 50.35 inches, but will double check!!
What should it be?
Re: Body Dimensions
Posted: Tue Jan 27, 2015 11:49 am
by woodypup59
I've been away and will check the lower mounting points tonight.
On the three cars i measured, the lower sill mounted seat belt captive nuts were between 50 and 50.5" apart.
All three have had complete floor replacements.
Re: Body Dimensions
Posted: Tue Jan 27, 2015 6:25 pm
by 62Morris_Cooper
Sorry but NicholasUpton made sense.
Thanks, every little helps!
