Machining costs
- Has thanked: 8 times
Machining costs
I'm very much out of the loop of engine building, it's been years.
What should I expect to pay for an overbore, line boring the mains and an acid dip?
- goff
Re: Machining costs
I paid £120 + Vat for a re-bore 12 months ago, Not including Shells , So i reckon you are up to £200 - £250 with line bore,
Crank grind is again around the same money , Nothing aint cheap.
- minimans
Re: Machining costs
Just got one back from the shop yesterday Hot tank. Bore and hone, line bore, resize and bush rods $550 + $150 to turn Crank.
- Been thanked: 5 times
Re: Machining costs
I have to drop off several engines for bore, clean, hone, grind shaft, cam bearings and freeze plugs. Rods reconditioned with new bolts, assembly balanced, guides, valves and hard exhaust seats. I will get a updated price list. Problem I'm running into is finding someone to bore under 2 5/8 block. I'm currently paying $160. US for 1275 bore, clean , hone. I have to pay $280. to bore a 850/998. I have no complaint with his quality, turn around or attitude. I currently have an 850 a 998 and a 997 to bore. As well as 4 1275 s two metros and two SPI s Steve (CTR)
Re: Machining costs
I got the new block for the Terrapin bored just before Christmas. £160 & I was quite happy.
Re: Machining costs
Thanks very much folks, what I was expecting. I'm unsure whether to get it line bored or not. The main housings seem round but the finish is awful, the previous one looked almost honed.
Bit paranoid about the brand new crank and that.
- minimans
Re: Machining costs
Line bore it better safe than sorry and you will know it's all square!wantafaster1 wrote:Thanks very much folks, what I was expecting. I'm unsure whether to get it line bored or not. The main housings seem round but the finish is awful, the previous one looked almost honed.
Re: Machining costs
Not that it means anything, I ran an auto machine shop till retirement 15 years ago. I now have a little classic mini only shop for fun and possible profit. Ask the machine shop how much to check line bore? The A+ blocks I have been dealing with all appear to have been honed after line bore. The A and other early blocks look as if they were line bored and left with machine finish. The shop I retired from just purchased a new Sunnen Line hone machine. Just as when I worked there, if I want the tooling to do engines as small as a mini I'll need to buy the tooling. With early engines line bore and balance are two very nice things to do. Steve (CTR)
- goff
Re: Machining costs
wantafaster1
Were are you based ???
Stanwoodhunter at Bawtry near Doncaster have been machining since the 50s and know what they are doing , Google them.
Goff
Goff
