Mk1 bonnet hinges?
Posted: Mon Dec 29, 2014 6:22 pm
by ivor badger 2
Was raking in back of garage. for some reason all the mk1 bonnet hinges are the same hand, ie the captive screws are on the same side. Were they all the same or were they sided?
Re: Mk1 bonnet hinges?
Posted: Mon Dec 29, 2014 6:31 pm
by InimiaD
Yup, they are sided going by AKM2. It's too cold to venture outside. :)
Posted: Mon Dec 29, 2014 6:42 pm
by Dr S
I'm sure they are sided.
Posted: Mon Dec 29, 2014 6:45 pm
by Th4neuk
Ooh if you have any spares going could you let me know please as am on the hunt for a pair.
Alan
Posted: Mon Dec 29, 2014 7:13 pm
by ivor badger 2
Th4neuk wrote:Ooh if you have any spares going could you let me know please as am on the hunt for a pair.
Alan
So far I have 4 all the same, which was what was confusing me and going by the colours, I can't work out where one came from.
Posted: Mon Dec 29, 2014 8:34 pm
by java gt
Sided for sure,nuts for securing the bonnet are always facing to outside of Mini.
Posted: Mon Dec 29, 2014 10:12 pm
by ivor badger 2
java gt wrote:Sided for sure,nuts for securing the bonnet are always facing to outside of Mini.
Well then they're all LH.
Posted: Tue Dec 30, 2014 3:36 pm
by cheleker
Backwards, java. Nuts on inside.
Posted: Tue Dec 30, 2014 5:49 pm
by java gt
Right you are Sir,I'll just go and stand in the corner especially seeing as I fitted the bonnet to my Estate on the 26th.
Posted: Tue Dec 30, 2014 8:44 pm
by tsumini
Looked at my 1960 Austin 850 and shows nuts to the inside also. Bonnet may not fit well if otherwise.
Bracket stampings themselves are not handed (at least not mine). The direction of the captive nuts determine handedness. You could change one by removing the captive screws and placing them in the other direction. Not sure this would be easy though; it appears that the screws were resistance welded in which case the screws would be difficult to remove without destroying them. Making screws shouldn't be difficult then weld/braze in right direction.
Posted: Tue Dec 30, 2014 9:44 pm
by BRI MK1
Nuts do face inwards and the fitting to the bulkhead there should be two thin brass washers a bit fiddly but you must fit them,
Posted: Wed Dec 31, 2014 7:00 am
by 1071 S
BRI MK1 wrote:Nuts do face inwards and the fitting to the bulkhead there should be two thin brass washers a bit fiddly but you must fit them,
A bit of thin double sided tape (each) works well for these. Just punch the bolt through the tape once the hinge has been slid into place...... Later Oz car use a kind of white plastic instead of brass..
Cheers, Ian
