Exhaust Manifold Identification.
MiniG
Post by MiniG »
Can anyone let me know what model these exhaust manifolds are from;
3 branches go into a inverted triangle section then a single branch bends under the floor into which the exhaust pipe fits (straight) ?.
And...believe its from a 'S' but which one ?
Has thanked: 125 times
Been thanked: 34 times
Re: Exhaust Manifold Identification.
Someone else maybe able to pick them better than me, however they are what were factory fitted to the Cooper and Cooper S models, as far as I know, they were the same, except those fitted to the 1275 S, these were about 3/8" taller.
360gts
Been thanked: 37 times
Post by 360gts »
Difficult to see the first manifold but the second is definitely the standard Cooper/S item.
As the previous post stated....1275 is 3/8 longer....than the 970 and 1071.
Difference in length is the result in the heigth difference in the 1275 block (to accommodate the longer stroke).
STG95F
Post by STG95F »
I Had one like the top photo fitted to my MK2 998 Cooper . i was told it was an aftermarket one , but i must say fitted very well
