Front car width. Too wide?
Posted: Sun Dec 14, 2014 9:16 pm
Hi,
I have packed my car away for winter and the foreseeable future with me moving to Australia although the car will eventually join me, but as I did I was starting to look a how to sort some issues.
One thing that does not look right to me is the front track width. The rear looks about right. The car has a dry subframe, 1.5 neg arms with minispares offset bushes, dry top arms and mini disc hubs and 7.5 disc setup. I have got the dunlop R7 165/70/10 tyres on minilife 4.5 "works" replica wheels.
The car has 0.1deg negative camber, 3 finger ride height (measured from top tyre to arch). The tyre walls budge out 15mm at the top and 20mm at the bottom compared to the rim of the wheel. With a straight edge placed on the side walls the tyre sticks out approx 16mm past the arch line. Have attached a poor drawn diagram of this. Both sides measure the same give or take a mm
Is this correct? I understand the appendix k cars use different tyres but there cars look like the tyres sit with in the arch line, with the minilife wheel being used by some racers. (this one has rose petals, couldn't find a decent pic with minilifes)
I also looked at a friends car, although he has the rose petals, he has r7's and that didn't look as wide.
I have checked the top and bottom arch length compared to another set, they measure the same.
Is it possible the almost new second hand front subframe I bought has the pickup points in the incorrect place? Maybe why it was being sold off cheaply.
I did hear that some of the appendix k racers have some special subframes which have had the pickups moved, but not sure if this is fact or fiction.
I didn't measure the actual track width and now its in storage, it wouldn't be all that easy to do.
I haven't but could measure the offset of the wheels but the rear looks ok and it has the same wheels/tyres.
Basically the car looks too wide to me and doesn't look pleasing on the eye. I have heard australia is very strict on car rules, can't imagine they will like tyres sitting past the arch line, and I don't really want to put any spats on it, although I suppose being red and white, it would look ok with black spats
Thanks for any help.
