Headlamp rims.
Headlamp rims.
Hi..
Does anyone knows if there's a difference on the original headlamp rims. Or are They all the same?
Was told that it was written in a lucas list that a rim i was looking at will fit a mini 850 from 60-62?
All the best
All the best
Re: Headlamp rims.
I have read about one change. The type with the rivet (holding a locating lug) at the top stopped in early '66 (maybe with the sealed beam change) and from then on, the type with the fake rivet was used.
Regards
Al
Regards
Al
Re: Headlamp rims.
I thought about that too 66S, but as I couldn't remember when they went to the fake rivet I didn't post yesterday.
Re: Headlamp rims.
Hello
Be careful if you buy a repro..
I bought a headlamp rim pair for my mk1,
I tried to fit about 2 hours and finally I made a scratch on the paint..
I put it in the garbage and I bought 2 used headlamp rims, I fitted it within 3 minutes!
- Vegard
Re: Headlamp rims.
A couple of years ago, maybe ten (
) you could buy aluminium headlamp rims. Are these still available somewhere?
I've only got a couple.
Re: Headlamp rims.
Theese are original. And can see the pin on the top of it. So there should be no problem with theese??
Re: Headlamp rims.
Moss do sell them...A couple of years ago, maybe ten () you could buy aluminium headlamp rims. Are these still available somewhere?
Re: Headlamp rims.
Are there normalt a bracket inside the rim. ( on top ) for a mini. or can the type
Without also be used??
Re: Headlamp rims.
There are a couple of the right type: Lucas number 554440 on ebay now
eBay item number:
381055049289
Michael
eBay item number:
381055049289
Michael
