1071 S gearbox casing numbers
Checking my facts here...I know the 1071 S came from the factory with a 22G190 gearbox casing, but did they ever have the 22G333 casing? The bible suggests only the 970 and 1275 S used the 333 but I could have sworn I read elsewhere later 1071s used the 333.
I've done a search on here and it hasn't turned up conclusive proof of either.
Re: 1071 S gearbox casing numbers
there is a long thread here from the MCR........ may shed some light!
http://forum.minicooper.org/forum/mk1-c ... ng-numbers
or, this really useful link on mk1!
http://mk1-performance-conversions.co.uk/gearboxes.pdf
so many variations for virtually every detail that nothing ever seems conclusive when researching mini coopers and s's
- Been thanked: 5 times
Yes late 1071,s and probably later 970,s all used a 22G 333 case .
But don,t ask me when they changed
Thanks evonaut, I have several versions of the table with gearbox parts and none of them list a 333 box on a 1071, which is why I asked on here. The MCR thread does seem to concur with 251ENG that some 1071s came with 333 casings.
I know of one 1071 built july/august 1964 that has a 22G 333 box .
Also built in a hydro shell from new , but with dry suspension
My July 7th 64 1071 has it's original engine trans. It's a 190 box.
- Toby
- Has thanked: 8 times
1071s had varios boxes fitted throughout their production run. To begin with they had 22G68 boxes which were ground out to take the throw of the different crank. After that the more common 22G190 was used. At the end of the production run the 22G333 was used.
T.
Where can we see this info?masnarda wrote:1071s had varios boxes fitted throughout their production run. To begin with they had 22G68 boxes which were ground out to take the throw of the different crank. After that the more common 22G190 was used. At the end of the production run the 22G333 was used.
My car compared to Parnell's book is less than 50# from the end
- Been thanked: 12 times
I'm having a similar discussion on the mcr . My mk1S made in the last two weeks of production . Should it have a 1522 or 333 . .... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Porsche 997 turbo S
I am from Essex
- mk1coopers
Interesting, I've got a 22G68 box that was fitted to a 1071, and it has been ground out on the webs, I guess there's no way of telling if its a factory one?masnarda wrote:1071s had varios boxes fitted throughout their production run. To begin with they had 22G68 boxes which were ground out to take the throw of the different crank.
- Toby
No record was kept for the switch over for the box types. The 22G68 boxes that were used were the adapted boxes that were initially used for the regular Coopers. On the lefthand side on the front of the boxes on the flat surface there ought to be a number, this will refer to the type of engine it was meant for and what type of diff that was fitted.
The factory produced monotone black 1071 was also produced very near the end of production. It also has a 1522 box fitted going by memory. But to my knowledge that was fitted later in it's life.
Yet again it's quite like that the factory just used what they had available at that time.
T.
OK so the first prototype cars used modified 997 22g68 boxes, I can believe that.
My 190 box that's original to my July 64 car also has the early laygear.
Anyone have later than July 9 64 with original trans still?
