How to Mount my seatbelts to the passenger bins
Luigi64
Post by Luigi64 »
Hi Guys,
I have just taken delivery of some NOS BMC service automatic Seatbelts, the number on the box says sc345p
So basically I need to know how to best mount the seatbelt 'reel' to the passenger bin. If anyone has done this please could you show me/ explain how you have done it to get best results?
Thanks in advance
Lewis
woodypup59
Has thanked: 8 times
Been thanked: 23 times
Re: How to Mount my seatbelts to the passenger bins
Post by woodypup59 »
I mounted the inertia reels in the pockets either side of the back seat - ( check the orientation the reels need to be at ).
I bought the webbing through the ashtray hole ( with a bespoke plastic guide ), up to the B post top mount, and then down to the usual sill mount.
olddad
Post by olddad »
Where do the children in the back seat put their cigarette ashes?
hanlminiman
Has thanked: 21 times
Been thanked: 36 times
Post by hanlminiman »
A tip from personal experience. Do not fix belt mounting direct to passenger bin without adding a suitable shaped strengthening plate. It is not strong enough, if needed in an accident !
Cliff
LarryLebel
Post by LarryLebel »
Use the same point on the sill as the end. I believe there is enough space between the seat and the sill. You don't have to do any welding.
woodypup59
LarryLebel wrote:Use the same point on the sill as the end. I believe there is enough space between the seat and the sill. You don't have to do any welding.
Depends which seat belts you use. Some intertia reels are bigger than others.
Luigi64
Post by Luigi64 »
Hi guys,
The type I have bought have the automatic reel that is marked up to be mounted vertically. I guess that means I need to bolt it to the floor inside the door bin by using a spreader plate and some anchor/welded nuts.
I think then I will have to remove a piece of the ashtray bracket and bin liner and slide the seat belt up through that and onto the top of the pillar before going back down to the floor.
I think it could end up a fairly big job!
rich@minispares.com
Post by rich@minispares.com »
olddad wrote:Where do the children in the back seat put their cigarette ashes?
just flick them out the windows :lol:
