Clutch slave cylinder Verto and pre Verto
Posted: Tue Oct 14, 2014 8:30 am
by almondgreen
Is it possible to use the piston and O ring from a verto clutch slave cylinder in a non vert clutch slave cylinder ?
Re: Clutch slave cylinder Verto and pre Verto
Posted: Tue Oct 14, 2014 11:02 am
by Smiffy
Originally the pistons where different sizes.
Posted: Tue Oct 14, 2014 11:42 am
by almondgreen
The diameter of the cylinders seem to be the same, so it should be no problem to change the pistons.
Or is there something I have overseen?
Posted: Tue Oct 14, 2014 11:54 am
by Smiffy
Probably got standardised (made the same size) later on, wasn't sure on that so didn't like to comment.
Posted: Tue Oct 14, 2014 12:16 pm
by rich@minispares.com
they are both 7/8 now, I wonder if it was the metro verto one that was different bore (or possibly the allegro one, as that had a different hose size as well?)
the problem with swopping pistons is that the verto one is twice as long as the non verto - so if its fitted its going to restrict the start position of the arm, and would probably lead to the piston popping out the end of the cylinder at full stroke?
the ring seal is halfway up on a verto piston, so it may be that the seal would escape out the end?, where as the cup seal is at the very end on a early one.
