Bonnet hinge & fan bracket bolts
Posted: Fri Sep 12, 2014 7:36 pm
by JC T ONE
Hi all,
does anyone make the welded bolts, with round and very flat head, that is fitted to the brackets for engine bay mounted fan & bonnet hinges.
Jens Christian
Re: Bonnet hinge & fan bracket bolts
Posted: Fri Sep 12, 2014 8:17 pm
by Andrew1967
Jens,
Just an idea, but it might be feasible to get a normal bolt/setscrew's head machined down in a lathe ?
Andrew
Posted: Fri Sep 12, 2014 9:18 pm
by Lakeland997
I think they're called 'weld studs' or 'weld screws' or 'projection weld studs'.
You can get them from suppliers like this but you probably need to order 50,000!
http://www.jhpfasteners.com/projection- ... -l-en.html
I wonder if M-Machine might have some?
Posted: Fri Sep 12, 2014 9:20 pm
by nick@dunsdale
Posted: Fri Sep 12, 2014 9:24 pm
by nick@dunsdale
Or there is elevator bolts or if you want to nit pick set screws
https://www.fastenal.com/web/products/f ... olts%22%7C~
Posted: Fri Sep 12, 2014 9:31 pm
Andrew1967 wrote:Jens,
Andrew
That's what I did. I could have bought ones that were close, but as Lakeland997 pointed out, the quantity was outa this world.
Posted: Fri Sep 12, 2014 11:23 pm
by Ollie78
Hi Jens
I reckon M-Machine will do them, I bought some reconditioned mk1/2 bonnet hinges a year or so ago from them for my project. They had just spot welded the new studs your after into old hinges.
Ollie
Posted: Sat Sep 13, 2014 2:54 pm
by JC T ONE
Thanks for all the reply.s
I will try M machine before I start butchering any more hinges.
Jens Christian
