Unleaded conversion
Posted: Wed Sep 03, 2014 3:39 pm
Hi,
I am building a motor for road rallying based upon a 1300GT engine.
I would like to do some light porting myself and have been thinking about the valve seats. I have built a few Lotus twin-cam engines and had hardened seats fitted along with new stainless steel valves and cosilbro guides. However in Lotus circles there are divided opinions on the strict necessity for fitting hardened seats. The heads are expensive though so I have tended to take a comprehensive approach.
Paul Exon has done all my Lotus head work and I will probably have him do the machining for the short A series motor - he's ex MED I understand and his work has always been first rate.
An A series head is a very different animal and, whilst simpler, I am less familiar with it.
So, what is the best advice - new seats and valves or can I get away with some porting, cleaning valves in a lathe and re cut the seats? The head, valves and seats are actually in good condition. My thoughts are that pulling and re doing a mini head is easy and cheap so this approach might be worthwhile on the basis that I don't mind getting my hands dirty again down in future if I have to pull the head.
What compression ratio would you advise to skim it to?
Thanks in anticipation.
Jon
Jon
