Powder coat in top arm tapers.
Posted: Fri Aug 22, 2014 1:52 pm
by Dr S
Hmm. My powder coated top arms have been coated inside the tapers and where the knuckle sits.
I'm ok about the knuckle (assuming it will go in with the coating in place) I'm less happy about the tapers.
Any thoughts? Am i just being fussy or should those joints be metal to metal ?
Nick
Re: Powder coat in top arm tapers.
Posted: Fri Aug 22, 2014 2:08 pm
by rich@minispares.com
I always clean them out with a witches hat pointy wire brush that goes in an electric drill
Posted: Fri Aug 22, 2014 2:18 pm
by Dr S
That sounds like a simple effective plan!
Right, now how to get the remnants of the blummin roller bearing out!
Posted: Fri Aug 22, 2014 2:23 pm
The tapers certainly do need to be clean metal to metal contact. If there is any powder coating in them they WILL shake loose.
Posted: Fri Aug 22, 2014 2:44 pm
by LuisM
Hi,
a shortened and slightly bent mini pushrod works fine for me when removing old bearings.... the adjuster side of the pushrod usually "grabs" the bearing cage ok from the inside . Few hammer taps and bearing is out.
regards
Luis
Posted: Fri Aug 22, 2014 3:57 pm
Rich was telling me about an exceptional bearing puller he bought from ebay only recently.
Posted: Fri Aug 22, 2014 4:02 pm
mk1 wrote:Rich was telling me about an exceptional bearing puller he bought from ebay only recently.
hmmm
it was neither exceptional, a bearing, or indeed a puller
...pay cheap, pay twice :evil:
Posted: Sat Aug 23, 2014 1:55 am
rich@minispares.com wrote:I always clean them out with a witches hat pointy wire brush that goes in an electric drill
+1. Then I libberally gease the outside of the cup before fitting. The next time it needs replacing, you'll likely find the cup will come out with your fingers :)
