Fuel gauge woes.
Posted: Wed Aug 13, 2014 10:36 pm
I've got all the electrics working (and a load of extras) on my woody project, but the fuel gauge doesn't want to play, properly.
The fuel sender is new. part no 21A 303 made circa 09 / 73. I couldn't get a reading at all until I added a seperate earth from the sender to the chassis.
There's about 9ltrs of fuel in the tank and the gauge reads 3/4 full.
I've changed the fuel gauge and the voltage stabiliser, but the gauge still reads incorrectly.
I've no idea what the speedo is off, it's just one i had spare and fitted it just to fill a hole in the dash. The script on the speedo is SN4421/00SA. 1248. I chose this particular speedo to compliment the speedo drive gears in the g/box.
The temp gauge works fine, so at least that is compatible with the stabiliser which is a 4 pin type.
I'm guessing I need a suitable voltage stabiliser to match the sender unit.
What do you electrical gurus suggest I should try next.
Thanks in anticipation.
