my rust bucket is currently trundling along with it's single weber 45....all seems to be fine. However, if i decide to put my foot down on the throttle a bit, the car just fills up with the smell of fuel...straight through the bulkhead and centre binnacle. Lift off again, and it will dissipate after a while.
Any suggestions as to what this might be? I can't see anything obvious going on. All the fuel lines etc seem to be good and i can't see any fuel leakage.
Cheers.
smelly weber
Re: smelly weber
Probably just "stand off" from the back of the carb. This is where you get a cloud of fuel vapour sitting just outside the carb trimpet. Very common on webers.
Re: smelly weber
Nevertheless a cleaned or new air filter should help.
Re: smelly weber
thnk guys...Astro wrote:Nevertheless a cleaned or now air filter should help.
that has prompted me to start reading...and it's lead me to velocity stack lengths (due to Mk1 mentioning 'stand off'), filters (thnx Astro) and even MED's 45DCOE DCR intake system!! Not sure how i got to that last one, but I assume google put filter, velocity stacks and weber together and got that one...
Anyway..bedtime reading me thinks.
Re: smelly weber
if there is enough place, perhaps one of these chromed filter boxes and just 15mm trumpets inside.
- pad4
Re: smelly weber
I knew Mark was posh - Its a trimpet old chap... Yea I know, shut up ...mk1 wrote:Probably just "stand off" from the back of the carb. This is where you get a cloud of fuel vapour sitting just outside the carb trimpet. Very common on webers.
Pad (with back to front webers)
- pad4
