Ignition switches
1071 S
Ignition switches
Post by 1071 S »
I pulled the ignition switch out of my 1071 today and it looks like its probably the original - dated 8/63 which would seem right for a 10/63 build.
Does anyone know what's connected to the pins marked "1", "2" and "3" ??
And, how do I change the key barrel?
Cheers, Ian
guru_1071
Re: Ignition switches
Post by guru_1071 »
ian
1 = white/red - solonoid
2 = white - ignition on
3 = brown/blue - live feed
to change the barrel you depress the little 'pip' that you can see in the side with a tiny screwdriver and the barrel will slide out - you need the key in it
1071 S
Post by 1071 S »
Thanks Guru, I shall have to look more carefully at the wires. I think they're original and each looks the same as its covered by a white (ish) braid.
I was guessing that 1 was the power feed because its in line with the key slot before its turned.
And, unfortunately, there is no pip - although there is a hole where one may have been; I will explore further..
ta ever so
