Piston rings for Omega pistons
PaulH
Post by PaulH »
Hi lads,
Hoping you guys might be able to point me in the right direction. I have a set of cast omega pistons they are of the 74mm verity. I have contacted MED and Omega them selves to get a set of rings but no luck. They are quite old and have a 1.2mm top ring and a 1.2mm second ring with a 4mm compression ring. The casting no is OP110.
If anyone has a set for sale or knows where one could purchase a set I would be very much obliged,
Kind regards,
Paul
Owner
Hickey Race Engineering
http://hrengineering.webs.com
surf-blue-850
Re: Piston rings for Omega pistons
Post by surf-blue-850 »
Try F W Thorntons, Shrewsbury.
They have all sorts of things and loose rings etc
scott6058
Post by scott6058 »
Same situation but may I suggest
http://cleviteonengine.com
For Perfect Circle rings.
Scott
Smiffy
Post by Smiffy »
Theres always Total Seal Rings, they'll do any size you want.
Has thanked: 61 times
Been thanked: 16 times
JPs will make anything you need, not only in size but also ring face types. They also have quite a huge variety on the shelf;-
http://www.jp.com.au/JPPistons.html
36inter
Post by 36inter »
Try Cox and Turner in Tintinhull near Yeovil
Pete
PaulH
Post by PaulH »
Jesues Thanks a Million lads thats awesome information, I will get on those leeds straight away. I knew of total seal but the cost of the rings,shipping and import duty here was more than the pistons are worth. I had completely forgot about FW Thorntans they sorted me out about 5 years ago with rings for a very early 850.
Thanks lads gota love this Forum,
regards,
Paul.
Owner
