45 dcoe 13 float level
kenb
Post by kenb »
Hi,
currently refurbing a 45 dcoe 13 and can't find a definitive value for the float ht, anyone help?
thanks
Ken
Smiffy
Re: 45 dcoe 13 float level
Post by Smiffy »
8mm with the float just touching the needle and 15mm full droop, make sure you don't set it on the soldered seam on the brass floats the 13 should have. The proper tool for the job has cut outs to clear said seam. Using a drill bit as some will tell you to use. Is just simply wrong.
In saying that these setting aren't set in stone and the float height can be used as another adjustment, when tuning your motor.
kenb
Post by kenb »
Thanks,
I'd found various numbers kicking around the ol'internet and prefered to at least start from webers spec
