Page 5 of 16
Re: Mk2 Cooper
Posted: Tue Mar 31, 2015 9:53 am
by Callum
Thanks Ollie, it must be quite common with the wings then, will be an easy fix for you.
I remembered that yours had cracked, I think I should of added a spreader plate inside the crossmember like you did also, maybe I still will.
Your build thread has been my biggest reference whilst working through mine, it's funny that I have passed you now, will have to figure the rest out for myself :D
Re: Mk2 Cooper
Posted: Tue Mar 31, 2015 10:14 am
by java gt
You are to be congratulated on your progress so far,I have read this and Ollies thread many times as I study how to tackle my MKI in the garage.I am slowly buying all the panels for it but the sterling/euro exchange has made it even more expensive at the moment.Looking forward to the next instalment of progress.
Re: Mk2 Cooper
Posted: Tue Mar 31, 2015 10:32 pm
by Callum
Cheers mate, it's good to know that it might help a few others with their projects
Re: Mk2 Cooper
Posted: Thu Apr 23, 2015 7:08 pm
by Callum
(update from what has been lost)
Got the wings welded to the front panel today, was going to prime them in my epoxy mastic aswell but one part of the 2 pack has gone off so need to order some more.
Re: Mk2 Cooper
Posted: Thu Apr 23, 2015 7:53 pm
by Callum
Started on changing the indicator plinths back to original. Didn't realise m machine made the smaller ones until recently, at first i thought i would have to leave it with the larger ones.
Got the passenger side in tonight
Before
Conversion panel tacked in
Welded and lininshed
Re: Mk2 Cooper
Posted: Thu Apr 23, 2015 9:02 pm
by STG95F
Is that a repair panel from M- Machine for the smaller indicators ? or do you have to buy a complete front panel ?
Re: Mk2 Cooper
Posted: Thu Apr 23, 2015 9:11 pm
by Callum
STG95F wrote:Is that a repair panel from M- Machine for the smaller indicators ? or do you have to buy a complete front panel ?
It's a repair panel, the 2nd picture shows the repair panel tacked in, the last picture shows it fully welded
Re: Mk2 Cooper
Posted: Thu Apr 23, 2015 11:06 pm
by 1064overbore
Didnt know later plinths were larger! when did they change over?
Oh and i must say, the panel gaps you're getting satisfy me more than they probably should.
Re: Mk2 Cooper
Posted: Thu Apr 23, 2015 11:08 pm
by STG95F
HI Callum . Thanks for the reply .
Is it a new panel M-Machine started doing recent ?
Re: Mk2 Cooper
Posted: Thu Apr 23, 2015 11:43 pm
by Callum
1064overbore wrote:Didnt know later plinths were larger! when did they change over?
Thanks very much, I have only recently found out about the different sizes myself so I'm not sure when they changed to the large one?
Re: Mk2 Cooper
Posted: Thu Apr 23, 2015 11:44 pm
by Callum
STG95F wrote:HI Callum . Thanks for the reply .
No problem Ian, I think it is relatively new, not sure if it's in their catalogue?
Re: Mk2 Cooper
Posted: Sat Apr 25, 2015 6:39 pm
by Callum
Got the other indicator plinth finished today.
Before
After
My primer arrived last week so i managed to get the inner wings and the inside of the front panel and wings painted, should be ready to weld on next week.
Re: Mk2 Cooper
Posted: Thu Apr 30, 2015 8:55 pm
by Callum
A mini is born! Front end is mostly welded on, couple of bits that were hard to access still to do once its back on the spit.
Will get the doors bolted on next and sort the gaps out
Re: Mk2 Cooper
Posted: Sun May 31, 2015 8:04 pm
by Callum
Cheers for the comments. Not had much to update really due to work and holidays but getting back to it again now. I had a load of parts acid dipped at the start of the month. Very happy with how it all came back, the bonnet and bootlid dont need any repairs, the doors are still on their original skins and only the driver's side needs a couple of small patches so chuffed with them.
Before
After
I spent today playing with the drivers door and it fits quite nice now, had to add some weld then file it back where there latch comes through the door as i think the latch is worn and sloppy meaning the door would pop out slightly when shut
Before
After
The gaps need sorting now which is the next job but the door tucks in nice on the bottom corner.
Re: Mk2 Cooper
Posted: Sun May 31, 2015 8:21 pm
by BRI MK1
Glad your happy with your bootlid car is looking good cheers Brian.
Re: Mk2 Cooper
Posted: Sun May 31, 2015 10:37 pm
by Tupers
You've done a lovely job of letting in those smaller indicator perches. The scuttle gaps are purdy as well.
Are the ATS Classics going on?
Re: Mk2 Cooper
Posted: Sun May 31, 2015 11:05 pm
by Callum
BRI MK1 wrote:Glad your happy with your bootlid car is looking good cheers Brian.
Thanks Brian yes very pleased with the bootlid not a spot of rust on it
Re: Mk2 Cooper
Posted: Sun May 31, 2015 11:37 pm
by Callum
Tupers wrote:You've done a lovely job of letting in those smaller indicator perches. The scuttle gaps are purdy as well.
Cheers, I'm not sure yet I don't want arches and i don't know if they will fit without?
Re: Mk2 Cooper
Posted: Mon Jun 01, 2015 7:34 am
by rolesyboy
Wow, Callum. You really are doing an incredible job of this car. I have seem this post and didn't realise it was you until I just spotted my old doors. They really are exceptional. Good luck. Will it be in colour and ready for Beaulieu in a fortnight?? Cheers. Mark
Re: Mk2 Cooper
Posted: Mon Jun 01, 2015 9:49 am
by Tupers
Callum wrote: Cheers, I'm not sure yet I don't want arches and i don't know if they will fit without?
What width are they?
I've got a set for 5x10's my estate, you can just about get away without running arches but it really depends on my style you're going for.
