Thanks Ollie, it must be quite common with the wings then, will be an easy fix for you.
I remembered that yours had cracked, I think I should of added a spreader plate inside the crossmember like you did also, maybe I still will.
Your build thread has been my biggest reference whilst working through mine, it's funny that I have passed you now, will have to figure the rest out for myself
You are to be congratulated on your progress so far,I have read this and Ollies thread many times as I study how to tackle my MKI in the garage.I am slowly buying all the panels for it but the sterling/euro exchange has made it even more expensive at the moment.Looking forward to the next instalment of progress.
Got the wings welded to the front panel today, was going to prime them in my epoxy mastic aswell but one part of the 2 pack has gone off so need to order some more.
Started on changing the indicator plinths back to original. Didn't realise m machine made the smaller ones until recently, at first i thought i would have to leave it with the larger ones.
My primer arrived last week so i managed to get the inner wings and the inside of the front panel and wings painted, should be ready to weld on next week.
Cheers for the comments. Not had much to update really due to work and holidays but getting back to it again now. I had a load of parts acid dipped at the start of the month. Very happy with how it all came back, the bonnet and bootlid dont need any repairs, the doors are still on their original skins and only the driver's side needs a couple of small patches so chuffed with them.
Before
After
I spent today playing with the drivers door and it fits quite nice now, had to add some weld then file it back where there latch comes through the door as i think the latch is worn and sloppy meaning the door would pop out slightly when shut
Before
After
The gaps need sorting now which is the next job but the door tucks in nice on the bottom corner.
Wow, Callum. You really are doing an incredible job of this car. I have seem this post and didn't realise it was you until I just spotted my old doors. They really are exceptional. Good luck. Will it be in colour and ready for Beaulieu in a fortnight?? Cheers. Mark
