RE-PRO RUBBER GAITERS
Has thanked: 235 times
Been thanked: 205 times
Re: RE-PRO RUBBER GAITERS
minimans wrote:Wasn't Delphi part of the Lucas group at one time?
Found this:-
2000: Delphi purchased UK based Lucas Diesel Systems from TRW Inc who purchased its parent LucasVarity plc in 1999.
Ronnie
Has thanked: 12 times
Been thanked: 29 times
Post by Ronnie »
Found this:-
Looking at the box they are part of lockheed :?:
minimans
Post by minimans »
Ronnie wrote:
Found this:-
Lockheed/lucas since the 70's
Work this out if you can.
03796206 : DELPHI LOCKHEED AUTOMOTIVE LIMITED
Is owned by
02860799 : DELPHI AUTOMOTIVE SYSTEMS UK LIMITED
is owned by
08257498 : DELPHI AUTOMOTIVE OPERATIONS UK LIMITED
is owned by
DELPHI LUXEMBOURG INVESTMENTS SARL
is owned by
DELPHI AUTOMOTIVE PLC
https://en.wikipedia.org/wiki/Delphi_Automotive
goff
Post by goff »
I started this thread a couple of years ago , This is the same dust cover now completely F****d , Car was in for a MOT in October and the nice man say's its failed with a smile :D :D on his face , OK whats wrong , The dust cover over the suspension as perished , Yes but it was perished last MOT and its only a year old , Hah things have changed and its now included in the test if water can get in , But do you know what a operation it is to change this cover , again he just smiled and shrugged his shoulders and said by the way its failed on the rear brakes also , That's another story.
Photo of the dust cover Janury 2014 , March 2015 and this October , completely F****d .
Big Question beside Delphi looking promising is any of the other rubber sold got any better or is it still SHITE
Minisprint!
Post by Minisprint! »
We use a rubber stretch gator for cv boots at work and they are near on indistructable, they have also started making boots for track rod ends and ball joints. They claimed the cv boots had a lifetime warranty . I've never changed one under warranty and I've been at the place 10years plus. Looking at that knuckle joint I'm sure a balljoint gator would fit
I rescued some old ones whilst stripping the radius arms I sold to Rich a few weeks back.
Very old but no splits !
Could probably spare a couple :)
jerry
Post by jerry »
Could try a bottle of superglue on the cracks. I find it quite theraputic!
Jerry
Anyone tried these from 'A-Series Spares?'
CV Boot Kit (Outer) Universal for Classic Mini
"This product is covered by a full OE Quality Warranty. This part matches Original Equipment (OE) quality specifications which means that it is at least as good if not better than the original part the manufacturer supplied the car with."
http://shop.aseriesspares.co.uk/shop/dr ... ssic-mini/
Looks like they come from 'Shaftec' of 'First Line' ? :-
Having built a reputation on offering premium quality products, Shaftec has become the leading brand of remanufactured driveshafts and CV joints in the UK.
http://www.shaftec.com/
http://www.partinfo.co.uk/articles/228
http://www.firstline.co.uk/products/cv- ... g-gaitors/
"On average, an original equipment specification rubber compound boot or gaiter will last for a minimum of three years (without damage) before a replacement is required.
Since the mid 1990’s, many vehicle manufacturers have been making the transition to a new compound called ‘thermoplastic’ which is lighter, stiffer and harder wearing. On average, a First Line original equipment specification thermoplastic boot or gaiter should last for ten years. However, this timescale can be significantly reduced due to excessive exposure to physical impact from loose road material such as gravel, glass and accident debris which can damage this stiffer (and hence more brittle) material. From an environmental perspective the thermoplastic material is biodegradable, unlike the traditional rubber compounds.
Typically the UK aftermarket is always on the lookout for cheaper alternative products. Some suppliers may offer a lower cost product, but this is usually at the expense of reducing the amount of material used (creating a thinner walled product) or by supplying a lower grade material which looks physically attractive but is technically below par for the job in hand. First Line CV boots and steering rack gaiters are manufactured to original equipment specifications and only the highest quality materials are used in their production. Every component is supplied complete with OE specification stainless steel clamps whilst CV boot kits also include a 50g sachet of high grade molybdenum disulphide grease as recommended by all vehicle manufacturers.
First Line recommends that you should check the CV boots and steering rack gaiters every 5-10,000 miles for excessive wear or deterioration. Any part should be replaced at the first sign of material fatigue."
http://www.partinfo.co.uk/articles/225
rich@minispares.com
Post by rich@minispares.com »
ive just bought a pair of these to test out on the trackrods of my GTM, its really obvious on that when they are failing as you can see them when the bonnet is up - not hidden away like on mini.
they are the perfect size for trackrod ends and would fit knuckle joints as well at a push, or he does sell a slightly larger one
he does them in blue, black and clear - I chose blue so I don't forget that they are the silicon one
they are expensive when compared to rubber ones, but if they last for ever worth looking at.
http://www.ebay.com/sch/i.html?_from=R4 ... 3&_sacat=0
will report back in a year!
Has thanked: 131 times
Been thanked: 113 times
I've just started a new thread regarding this subject - of piss poor rubber boots and seals etc. If you can get good rubber stuff for your Nortons and Triumphs there's no reason why the parts suppliers shouldn't be able to get it too
POLY UPGRADE TRACK ROD END/KNUCKLE GAITER
Minispares Part No. 21A425EVO
Polyurethane upgraded gaiter for all knuckle joints and many track rod ends
(For standard rubber versions see 21A425)
Please note- this does not fit all track rod ends as so many genuine and aftermarket parts have been supplied in 55 years. It does however fit every suspension knuckle ball joint GSV1118 ever made.
https://www.minispares.com/product/Clas ... o%20search
Folks will whinge about the cost now.
:lol:
I think the word Poly has done it for me Mark :? :lol:
goff
Post by goff »
mk1 wrote:Folks will whinge about the cost now.
:lol:
F***ING HOW MUCH :lol: :lol: :lol:
robert_stryk
Post by robert_stryk »
how about CV gaiters, the last ones I fitted lasted all of two month before splitting. :oops: Given the work involved would rather pay more and not redo the job every couple of month.
Daz1968
Post by Daz1968 »
Not used them myself as I am still using nos parts,
But these are listed as high quality
http://www.somerfordmini.co.uk/eshop/in ... s_id=16990
Has thanked: 179 times
Been thanked: 62 times
Peter Laidler wrote:I've just started a new thread regarding this subject - of piss poor rubber boots and seals etc. If you can get good rubber stuff for your Nortons and Triumphs there's no reason why the parts suppliers shouldn't be able to get it too
Quite and something doesn't add up in regards to rubber we are being pedaled.
We've got some 10 pages in this very thread of examples poor rubber parts for our cars that is currently on the market.
However, items like the Rubber Cones, Competition Bump Stops, Ordinary Bump Stops - all of which are made in the UK and then there's the range of rubber from Japan - all these are OEM quality or better.
So, how is it some rubbers, like Goff's Knuckle Boots, CV Boots, Rack Boots, Suspension Arm Seals, Ball Joint Covers etc are crud ?
As mentioned elsewhere in this thread, it's nothing to do with so called 'modern rubber', I've just listed specific examples of 'modern rubber' that is fine as well as that that's currently fitted to Nortons Triumphs as well as all other new cars on the market today.
Volumes don't have anything to do with it either.
While the Poly bits for some stuff maybe an interim solution, I don't feel it's the answer and clearly, there isn't a need to go down that road.
I seem to recall that 'modern rubber' is made from reconstituted rubber. made from rubber granules and compressed under heat. Yes, it's rubber but not 'real' rubber of a known quality. It's a mix of all-sorts. And this is what disintegrates. I could be wrong and even my chemist classic car owner James isn't that certaibn. But Norton and Triumph owners know. And if you sell them crap reconstituted foot rests and kick start rubbers they'd come round and........... They won't accept it!
I cannot be the only person who is bored to death with this particular subject. It has been covered many, many times & as far as I can see has been done to death.
Ok, some suppliers have had / have ongoing issues with crap rubber components. Where this is the case I would suggest the buyer takes them back & gets a refund. If we all keep doing this they will eventually get the message that these parts aren't good enough.
There are long lasting good quality alternatives available, these are expensive, but seem to do the trick.
Since this issue was first discussed here, Catmint has started supplying top quality alternatives to some parts, and Minispares now seem to be offering a better quality knuckle / ball joint gaiter. To my mind this seems to indicate that things are moving in the right direction.
NOS parts are available too if you are prepared to hunt them down & pay the price.
So there ARE alternatives out there, simply whinging on about stuff & not doing anything constructive seems pointless to me.
