Page 5 of 9
Re: Barn find MK 2 Rally car
Posted: Sat Aug 24, 2019 10:06 pm
by e-type
Now with wheels
Posted: Sat Aug 24, 2019 10:09 pm
by e-type
Pre owned
![Smile :-)](./images/smilies/icon_e_smile.gif)
Avon CR6ZZ tyres, and patina wheels
Posted: Sat Oct 26, 2019 10:43 pm
by e-type
Not much done the last 2 months, but the gearbox is now ready. All the parts from the old box is reused in the "new" housing.
So it is genuine ST sc/cr 4 synchro, with Salisbury LSD, and 4.26 diff ratio. Also the homemade "splash plate" went back in.
Posted: Sat Oct 26, 2019 10:48 pm
by e-type
1:1 Jack Knight drop gears with Timken bearings
Posted: Sat Oct 26, 2019 10:52 pm
by e-type
The tough gaskets will be used
Posted: Fri Nov 08, 2019 4:15 pm
by e-type
Sunday, I started the engine build, I did fear, that the valves could hit the pistons, so I fitted the cylinderhead, without the gasket, and sure enough the exhaust valve hit the piston just before TDC.
Posted: Fri Nov 08, 2019 7:30 pm
by Fanfaniracing
I like this a lot! What cam do you use?
Posted: Sun Nov 10, 2019 12:43 am
by e-type
It is the Minispares C-AEG311 Rally evolution, duration 306 in and 300 out timing 53/73 in and 74/46. This cam has more exhaust lift.
but I do have another, that came with the car, and it should be of Jim Whitehouse design, and is also duration 306 in and 300 out, but 48/78 in and 75/45 out.
Posted: Mon Nov 11, 2019 12:04 pm
by e-type
These useable std size forged pistons, came with the car, the Cut outs for the Valves needs to be about 1 mm deeper. Anybody knows of the piston brand HG?
Posted: Mon Nov 11, 2019 3:49 pm
by wantafaster1
Possibly " Hepolite and Grandage"
Not sure if I have spelled that correctly
Posted: Mon Nov 11, 2019 4:39 pm
by GRAHAMC
Hepworth and Grandage
Posted: Tue Nov 12, 2019 1:30 am
by wantafaster1
That's it!
Posted: Tue Nov 12, 2019 6:05 am
by r.tec
Hepworth & Grandage -> AE Hepolite -> Federal Mogul -> NĂ¼ral
Posted: Sat Nov 23, 2019 2:17 pm
by e-type
After 3 weeks, working in Switzerland, it is nice to be back home in the garage. I have had a closer look, at the 8 port cam installation. With the AEG 625 "S" rods, a lot of the head needs to be removed from the bolt, to clear the cam.
Posted: Sat Nov 23, 2019 2:31 pm
by e-type
Fortunately, it is a set of AEG 177 conrods, I have chosen to work on for this engine. Look have much lower, the bolt sits in the conrod. Is it always like this?
Posted: Sun Nov 24, 2019 10:33 am
by 251 ENG
Yes all AEG 177 rods are like that , the original BMC rod bolts were shorter
I believe BMC changed the rod design because some rods failed
Posted: Fri Jan 17, 2020 12:00 pm
by e-type
After som turning and milling, the conrods is now ready.
For the 177 rods the new ARP bolts have been shortened by 3mm.
Before they where about 680g, and now 600g
Posted: Fri Jan 17, 2020 12:03 pm
Very nice job!
I love your Con Rod balance
Posted: Sat Feb 22, 2020 8:27 pm
by e-type
Fitting the pistons
Posted: Sat Feb 22, 2020 8:32 pm
by e-type
After trial fitting, with the chosen cam, I made the pockets 0,70mm deeper
