Good cam choice for a 1275 S
Exminiman
Has thanked: 21 times
Re: Good cam choice for a 1275 S
Post by Exminiman »
I wonder how the RE13 would wear with some sensible millage, does anyone have experience of this?
Assume this would be effected by its ramp angles and total lift ?
Cheeser
Post by Cheeser »
My experience regarding mileage with RE13ot ( note this is NOT RE13pp), first engine I ran for about 30k miles using 1.5 rockers and did not have any significant cam wear. The current engine has done about 4 to 5k miles again with 1.5 rockers and is performing well. Factors that may influence others decisions as to suitability for their use are that engines are in a Lotus 7 weighing about 450kg with SCCR box and pulling about 16mph in top. Usage does not normally include motorway or city driving but A and B roads.
BAD942B
Post by BAD942B »
Exminiman wrote: Sat Aug 24, 2024 10:04 am I wonder how the RE13 would wear with some sensible millage, does anyone have experience of this?
Calver ST insist you use their followers which they say are ground correctly (not all are apparently) , the cam is centre drilled & all lobes / followers surfaces are fed with oil driilings from that gallery in the correct place so should have a reasonably long life
Chris A
BAD942B
Post by BAD942B »
BAD942B wrote: Sat Aug 24, 2024 11:13 pm
cam grinding has come on since the 1960s & 70s in terms of accuracy aswell
Chris A
