Page 22 of 43
Posted: Tue Jun 04, 2019 12:22 pm
by Nick W
lt must be a nice feeling to know everything will fit after its painted
the battery lead channel was a bit uneven on mine...hard to sort after paint
Posted: Tue Jun 04, 2019 3:56 pm
by Andrew1967
Nick W wrote:lt must be a nice feeling to know everything will fit after its painted
Better add that to the snagging list Nick
I think this comes from building 'bespoke' machinery as my day job where, if the machines are not 'black built' before paint, you can guarantee there'll be problems at final assembly with parts not fitting !!
Posted: Tue Jun 04, 2019 3:59 pm
by Andrew1967
Peter .... it's a good idea in theory ... 'The DIY restorers guide to restoring a rotten Mk1 Cooper S, in a domestic garage' ....
Might please someone
Maybe I will do something ...
Posted: Thu Jun 06, 2019 8:54 am
by Andrew1967
Following Peter's request in the Headlamp fitting thread in the Technical section, here a pic of the squared off headlamp bowl fixing holes.
I have been on holiday from work this week and forgot to bring my mates square drill bit home to do this job (a long standing joke on one of our younger members of staff who was having a blonde moment at the time
So, quite simple, I enlarged the existing holes with a 1mm incremental step drill (good quality step drills are fantastic bits of kit) to just under the required size and then filed the corners square with a square file until a decent fit was achieved with the fasteners. Simples !!
I did use my pencil die grinder (Blue Point - expensive but a brilliant thing for detailing in tight corners etc) to remove some of the wing metal from around a hole on each wing to allow the fastener to sit flush with the bowl mounting plate.
I guess someone is now going to say the holes aren't correctly orientated
Posted: Thu Jun 06, 2019 10:15 am
by BLT
What is the reason for the square holes? Won't round holes do?
Anyway, looking great Andrew. You've done more on that car in 6 months than I've got done in 3 years.
Posted: Thu Jun 06, 2019 10:26 am
by timmy201
BLT wrote:What is the reason for the square holes? Won't round holes do?
The plastic clips that the headlight bowls screw into are square. There are some photos in the thread below:
viewtopic.php?f=3&t=25551
Posted: Thu Jun 06, 2019 11:04 am
by BLT
Ok thanks. Where can I buy the clips?
Posted: Thu Jun 06, 2019 12:17 pm
by Peter Laidler
And don't forget that the small 'head' of the square plastic nuts will prevent metal to metal contact as well as the metal screw graunching its way through the metal wing. Not totally relevant here because there's a rubber seal around the bowl. But it is relevant for the grille retaining screws.
Where can you buy the clip thinggies....... Can you put the retailers details up again SurfBlue?
Thanks Andy
Posted: Thu Jun 06, 2019 2:53 pm
by BLT
Posted: Thu Jun 06, 2019 5:14 pm
by Andrew1967
Yes, they are the type Richard, although I found some NOS from auto jumbles over the years.
Posted: Fri Jun 07, 2019 7:39 am
by Toby
Andrew1967 wrote:I guess someone is now going to say the holes aren't correctly orientated
You're right Andrew, I'll get you a pic of a nos headlamp ring later on
Posted: Fri Jun 07, 2019 7:48 am
by Andrew1967
Toby wrote:Andrew1967 wrote:I guess someone is now going to say the holes aren't correctly orientated
Well, we'll all learn something new today then Toby. I'm not altering them though
Posted: Fri Jun 07, 2019 8:43 am
by Costafortune
Painted this year, and reassembly starting?
Wonder what the engine's like?
Posted: Fri Jun 07, 2019 8:51 am
by Andrew1967
2 pack primer and maybe initial colour coats by end of year but top coats will be next year.
Engine, thought to be original (by block number dating and physical evidence) currently at plus 40 and will need rebore etc. Currently has 4 sync box but have 333 box to correct that.
Posted: Sat Jun 08, 2019 2:43 pm
by Costafortune
Don't leave it in primer for months as it absorbs moisture - get a good base coat on. That will settle over the months, find any imperfections and be a very good base to flat off and top coat.
Posted: Sat Jun 08, 2019 5:53 pm
by Andrew1967
Costafortune wrote:Don't leave it in primer for months as it absorbs moisture - get a good base coat on. That will settle over the months, find any imperfections and be a very good base to flat off and top coat.
I’m using an 2k epoxy primer that is waterproof but yes, normally primer is porous so good advice
Posted: Sat Jun 22, 2019 4:58 pm
by Andrew1967
First instalment of primer today
Posted: Sat Jun 22, 2019 7:04 pm
by Daz1968
Always looks better even with primer, makes you feel like you are getting somewhere after all the hard work.
Posted: Sat Jun 22, 2019 9:59 pm
by swifty
No right hand tank bracket on the rear seat upright Andrew ? . Ive forgot that many times in the past . And had to mix up a small amount of paint and puff in ... ken
Posted: Sat Jun 22, 2019 10:49 pm
by timmy201
He may be keeping it single tank as per the factory delivered spec?
