Smiffy wrote:ianh1968 wrote:Discuss - As regards fitting a nice soft bronze bush to the taper...
Ian
But you don't really think soft bronze is used do you ?
Bronze is a alloy, a alloy is a combination of more than one type of metal.
I'm a bit thick, me, I can't tell the difference between cheese and proper metal...
I made the assumption that if a steel locking washer can be soft, then it is
more than likely that some kind of bronze alloy would be even softer.
A very quick bit of research shows that a "hard steel" is typically 55-66
on the Rockwell C Scale.
Phosphor Bronze is 92-98 on the Rockwell B Scale.
92-98 Rockwell B equates approximately to 11-21 as Rockwell C.
On the face of it, 11-21 RHC vs 55-66 RHC would appear to be quite soft...
I am sure that there will be an expert amongst us that will be able to clarify
matters.
Ian
