![Image](http://i710.photobucket.com/albums/ww102/surfblue63/Austin/2008_09080008.jpg)
1963 Super de-luxe
Re: 1963 Super de-luxe
Here's a shot of the dash which shows the mileage on the day I got the car home in September 2008. Also note the position of the washer plunger.
- minidean
Yes, why was the washer plunger on the wrong side???surfblue63 wrote:Here's a shot of the dash which shows the mileage on the day I got the car home in September 2008. Also note the position of the washer plunger.
UPR 65 1963 MK1 Super Deluxe
FTX 217K 1971 MK3 Cooper S
- minidean
Fitted the correct carb today and after a few mishaps with the fuel pump I finally got the car to turn over. After a few attempts to get it started the starter motor packed up. I stripped it down cleaned the bushes then replaced it. Now it works a treat but still no spark. might be the coil but any other ideas?
- miniminor
Is the mileage magically reducing?
72k in one photo, 61K in the next![Laughing :lol:](./images/smilies/icon_lol.gif)
2014 Freelander 2 SD4
- minidean
61k september 2008. 72k september 2013.miniminor wrote:Is the mileage magically reducing?
![Smile :)](./images/smilies/icon_e_smile.gif)
- minidean
Came home from work early today and got a few hours in the garage.
- Chris64
- minidean
Three for the rear and the curved one is for the front seat belts in the centre.Chris64 wrote:Looking great!![]()
Are those seat belt mounts for the rear?
- minidean
Good news and bad news. The car started for the first time today, it sounded sweet! The bad news is that the water pump seems to be leaking quite badly, the vacuum advance unit spring to the distributor plate seems to be broken, and I have break or clutch fluid or something leaking into the car. any ideas???
- Pete
- Has thanked: 39 times
- Been thanked: 102 times
That looks like engine oil leaking from the oil pressure pipe that goes to the rear of the gauge ?
- minidean
Now i feel really silly, Pete your a star, you were absolutely right. ThanksPete wrote:That looks like engine oil leaking from the oil pressure pipe that goes to the rear of the gauge ?
- Pete
By the way Dean if you need to replace the original fresh air heater hose (seems to be plastic now ?) you can get a repro rubber Mk1 type here :
http://www.totalrepellents.co.uk/minibi ... rubber.htm
- minidean
New fresh air pipe came today it looks great but it's a lot stiffer than the original. Thanks Pete.
I also manage to get and original coventry radiator. Thanks Nick
- minidean
I decided to go with powder blue seat belts from Seatbelt Planet, Oklahoma.
They should look super when fitted,love the stickers as well.An Ebay special?
- minidean
Beautifully restored steering wheel
