Page 3 of 3
Re: Daniel's 1966 Morris Mini-Minor Super Deluxe
Posted: Mon Dec 05, 2011 3:04 pm
by dhenry
Posted: Mon Dec 05, 2011 3:45 pm
by guru_1071
i bet its easier now its inside!
Posted: Mon Dec 05, 2011 5:04 pm
by Etienne B.
Hi Daniel,
Nice to see you are progressing, keep it going !
Cheers, Etienne
Posted: Tue Dec 06, 2011 8:15 am
by dhenry
yes it is easier. nobody likes to weld in the rain.
Posted: Tue Dec 06, 2011 3:03 pm
by HuwGreenMiniVan
Those welds look a bit thick. Puddle welds are they? Got to watch you don't thin the surrounding metal and reduce strength. Use as low a setting on a mig welder for puddle welds that you can get away with to not reduce the thickness of the surrounding upper panel with a weld. Better to drill the old spot weld out, fil it in, grind it flat, and old fashion spot weld it in between old spot welds. But with rust about can be difficult.
Posted: Tue Dec 06, 2011 3:42 pm
by dhenry
cheers, i will bear that in mind. thanks
Posted: Thu Dec 13, 2012 9:19 pm
by dhenry
Posted: Fri Dec 14, 2012 8:35 am
by Etienne B.
Hi Daniel,
Nice to see you make progress.
The dash panel is looking good : which crackle paint did you use ?
I still have to do mine.
Also, don't you keep your front disk brakes ? Are they 7' Cooper disks ?
Kind regards,
Etienne
Posted: Fri Dec 14, 2012 8:41 am
by dhenry
The wrinkle paint is VHT wrinkle plus. It is excellent. Highly recommended.
These wheels are mk3 steels and fit over my 7.5" Cooper S discs easily.
Posted: Fri Dec 14, 2012 10:31 am
by Etienne B.
Thank you Daniel,
I didn't know those wheels would fit over S disks.
Should give a nice understated look.
Etienne
