Page 3 of 13
Re: 1973 gtm coupe
Posted: Sun Aug 15, 2010 10:36 pm
by tedmcedd
that elan looks so sexy!
not much special to do RE: fibreglass painting.... just dont use celly as that will crack....
looking good sir!
i should have quite an exciting update on tuesday....
Ed
Re: 1973 gtm coupe
Posted: Thu Aug 19, 2010 8:51 am
by guru_1071
ive got the outside wing started.
i first went over it with a flap wheel to pull all the damaged gel coat & fibreglass out of the really bad areas. i also chased out most of the impact cracks that had spread all over the wing and cracked the gel coat.
i then laid the normal grp mat iinto the deeper damaged areas and then overlaid the whole area with grp tissue.
ive also bought some red pigment, so the end result will be easier to sand.
in the above pictures you can see that the shape is starting to look right, but is still a bit lumpy round the arch where so much of the original damage was.
however
three hours of hand block sanding later.........
the arch is about perfect, with just a couple of little dips, i laid a bit more on last night and by next week it should be ready for the smallest ammount of body filler ever.
Re: 1973 gtm coupe
Posted: Fri Sep 03, 2010 8:57 am
by guru_1071
after the smallest amount of filler ever the arch is about 99% right, it just needs a little more and i will be happy with it
it needs a bit more on the return part underneath, but i will do that when i tip it on its side.
ive also got the screen out, which was difficult as it had been bonded in, it took about an hour of slowly cutting the seal away, then cutting through the sikaflex.
the whole car is now sanded and all the rough edges from the moulds have been removed - might even be in primer by next week
ive also started patching the bits im not happy with inside, im going to bond over all the joins where the various parts where pop rivited together.
spot the bit of a stick been used as a high tech mould former!!!
Re: 1973 gtm coupe
Posted: Sat Sep 04, 2010 10:44 pm
by tedmcedd
guru_1071 wrote:might even be in primer by next week
famous last words...
you'll have to get your sanding block back out if you want it as shiney as mine
lol!!
looks good though, top ob on the arch repair!
Ed
Re: 1973 gtm coupe
Posted: Mon Sep 06, 2010 9:10 am
by guru_1071
yacht varnish edmund, yacht varnish!
Re: 1973 gtm coupe
Posted: Mon Sep 06, 2010 8:08 pm
by austinisuseless
Blimey, yacht vanish. Guru has gone to sea, in inner lancashire!
http://www.youtube.com/watch?v=D42nI0VGiW4
Re: 1973 gtm coupe
Posted: Mon Sep 06, 2010 9:10 pm
by tedmcedd
thinking about the enormous back lights, you could make a big plate out of ally to go on the back, paint it matt black, get some smaller lights on the scene like pickup/van ones....
that pic of the back end with the large holes in just made me think... curved at the top and along that body line just inder the lights...
Re: 1973 gtm coupe
Posted: Mon Sep 06, 2010 9:15 pm
by tomkidd
Looking good Rich, is the 8 port going in this?
Re: 1973 gtm coupe
Posted: Mon Sep 06, 2010 9:42 pm
by COOPERCO
This what I had for rear lights. Blacked out the pockets the original 'truck like' units were in, fitted some new round lights (same as on Zonda's!), folded up some mesh & painted that black too.
Re: 1973 gtm coupe
Posted: Mon Sep 06, 2010 9:52 pm
by Vegard
I like your skills Rich. I guess all handicapped people living on social benefit hates you
Re: 1973 gtm coupe
Posted: Tue Sep 07, 2010 1:59 pm
by guru_1071
tomkidd wrote:Looking good Rich, is the 8 port going in this?
tom, nope its having a 1071 with a tall diff in it
Re: 1973 gtm coupe
Posted: Tue Sep 07, 2010 2:00 pm
by guru_1071
Vegard wrote:I like your skills Rich. I guess all handicapped people living on social benefit hates you
eh?
Re: 1973 gtm coupe
Posted: Tue Sep 07, 2010 5:25 pm
by Pandora
tedmcedd wrote:thinking about the enormous back lights, you could make a big plate out of ally to go on the back, paint it matt black, get some smaller lights on the scene like pickup/van ones....
Nah, cut the whole lot out and put a black mesh panel in with Mk1 Cortina 'Ban the bomb' lights.
Al (who just happens to have a set of lights available.......)
Re: 1973 gtm coupe
Posted: Tue Sep 07, 2010 5:32 pm
by guru_1071
Pandora wrote:tedmcedd wrote:thinking about the enormous back lights, you could make a big plate out of ally to go on the back, paint it matt black, get some smaller lights on the scene like pickup/van ones....
p
it wont work, the later gtms (like mine) have a flat panel which would be smaller them the big round lights.
the only way would be to flatten off the whole rear end.
ive see a car with some fitted and it looked really rubbish.
ive decided to leave mine with the big square lights - ive not yet seen a car with a pair of round lights fitted that i like the look of - they are all either too big, too small or too modern (and beleive me, ive bought a few sets!)
i guess i just need to accept that its 'of period' and leave it at that!
i cant see the back when im driving it anyway!
Re: 1973 gtm coupe
Posted: Tue Sep 07, 2010 7:12 pm
by Vegard
guru_1071 wrote:Vegard wrote:I like your skills Rich. I guess all handicapped people living on social benefit hates you
eh?
You prove that handicapped people can infact work
Re: 1973 gtm coupe
Posted: Wed Sep 08, 2010 8:52 am
by guru_1071
Vegard wrote:guru_1071 wrote:Vegard wrote:I like your skills Rich. I guess all handicapped people living on social benefit hates you
eh?
i can still kick your arse!
Re: 1973 gtm coupe
Posted: Sat Sep 11, 2010 2:36 pm
by austinisuseless
guru_1071 wrote:tomkidd wrote:Looking good Rich, is the 8 port going in this?
Since the spark plugs are a couple of inches from the seats, carbs might be ambitious!
Re: 1973 gtm coupe
Posted: Sat Sep 18, 2010 10:27 am
by guru_1071
got a bit more done
all the rear underneath is now stonechipped white (will be painted red). the bits of the engine bay are done as well, but i will probably paint these black. you can also see the grp'ing ive done between the rear boot and the engine bay
note quality masking off job - and the no expense spent 'light on a stick' that i made from stuff my garage landlady left there!!!
ive also started on the front pillers - these have a metal tube that is poked in from the outside, then glassed to the top and welded to the bulkhead. both the tubes where in different places and it would have been to invasive to hack them out, so it was a case of trying to make them both look a little more equal.
the previous owner had just stuck hairy felt stuff over, but it hadnt stuck very well, so i decided to make an inner skin part so that its flat like a mini.
passenger side piller - you can see the metal tube (the hairy felt has been peeled off)
expandy foam - i did this to bulk it up and fill the void beteen the metal tube and the outer skin - it wasnt as successful as i hoped - the foam i bought dried to a very soft sponge cake type of consistancy - which was easy to cut into an appoximate shape, but virtually impossible to sand into a final shape
layered up with some mat and a final coat of tissue - it will need a rough sand and some filler to get it close, but im going to cover them in black vinyl so it doesnt have to be 100%. ive had to be careful to make allowances for the windscreen seal fitting in against the metal tube (doesnt photo very well)
Re: 1973 gtm coupe
Posted: Sat Sep 18, 2010 12:58 pm
by chris-pilling
looking good guru!
Re: 1973 gtm coupe
Posted: Sat Sep 18, 2010 2:12 pm
by JanWulf
BMW 2002:
