62 Austin Seven Cooper
anis
Re: 62 Austin Seven Cooper
Post by anis »
Looking great!
Fanfaniracing
Has thanked: 8 times
Been thanked: 22 times
Post by Fanfaniracing »
Started with the stripping today!
I‘m trying to work somr houres every day bevore Work...
Does somebody knows the colour code of the orange primer used pn
Mk 1 Minis?
Fanfaniracing
Finally got the front clean and ready for primer.
Fanfaniracing
Primer went a little bit to orange...
Fanfaniracing
Some update: just got the car back from dry ice cleaning.
Never expected such a grat result! All the tar underseal has gone!
anis
Post by anis »
Wow! That’s very clean!
Wherebdid you do this and how much did it cost?
Fanfaniracing
A Guy next to Kerzers. I payd 400.- Chf for all four Wheelarches and Engine Bay. A very ok price in my opinion!
anis
Post by anis »
Definetly ok. Looking great!
Freiburger Cooper!!!
Has thanked: 139 times
Been thanked: 118 times
Dry ice cleaning.......... what/how is it? It's certainly VERY effective.
Yes it was also done on an American car restoring programe at Discovery.
:P
Fanfaniracing
Dry Ice cleaning is in fact like Sandblasting but with frozen co2. It works fine to remove tar, fat, oil or all sort of organic dirt. It is a very gentle way to clean the underfloor or engine and so on...
The car can stay together as it is not abrasive and don‘t destroy rubber, plastic or paint. So Brake lines, gaiters, spark leads ect will just become clean.
Fanfaniracing
Put the brake booster in place with manufacuring some brackets and pipes. Will need the space in the engine room for air filter and auxilary radiator...
Fanfaniracing
Test fit of the Subframe to make the last brake pipe.
Simon776
Post by Simon776 »
Nice pipework but you seem to have servo assisted back brakes and no connection to the front brakes? :shock:
Fanfaniracing
Good Eyes Simon!
On this pic the Pipe from the servo to the subframe is not not built. I had to drill a hole and build the pipe. It was late when whe were finished and no pic was made... :roll:
nick@dunsdale
Has thanked: 12 times
Post by nick@dunsdale »
Fanfaniracing wrote: Does somebody knows the colour code of the orange primer used pn
Mk 1 Minis?
Sorry bit late to be offering an answer, but it looks quite close to red lead primer, common for use as an anti corrosion primer
car is looking great :D
Fanfaniracing
Some little progress today...
Fanfaniracing
Fitted the new overhault Speedo and Speedwell Rev counter
Fanfaniracing
So, after to less time and a too long to do list Whe finally get it done! The mini is MOT‘d and is proudly wearing now his Arden powered Engine! Hurra!
Got the engine in last night and could made it running and driving this morning.
Just crazy the noise it makes especially the Dog box.
Now i have to finetune these Amals to get the maximum out of this Setup and if then everything is working make the finish of the car.
Last edited by Fanfaniracing on Wed Aug 31, 2022 11:44 am, edited 1 time in total.
Charlynsane
Post by Charlynsane »
Fantastic work!
What's your calipers?
What sort of bonnet will you fit? could be better to keep the original bonnet with short stack?
