twin tank venting
gogsymac
Re: twin tank venting
Post by gogsymac »
I found a source for these slide in clips - or at least ones which look very similar. Can't recall where I got them but can find out if anyone needs to know.
I have quite a few spare so if anyone wants some just let me know.
Pics below.
steve1071
Post by steve1071 »
360gts wrote: Thu Apr 08, 2021 2:48 pm
steve1071 wrote: Thu Apr 08, 2021 9:02 am Anyone know the change over date from the bolted clips to the welded tabs?
Here are some pictures of my Nov 5 built 1275...(complete with factory paint runs).....has the slide in clips.
I suspect that these were eliminated and welded tabs were fitted with the introduction of the RH tank as standard equipment in Jan. 66
P/N 13H9524.....I have a sneaky suspicion that this clip was something that was used on other vehicles. I seem to recall seeing them ...somewhere!
The fact that they appear to be painted green....perhaps they were used on the Lan Rover....just a thought!!!
Pretty sure BMC wouldn't have produced the clip for a small number of RH tank cars.
Thanks Dermott, are the rear boot board brackets spot welded or riveted?
360gts
Been thanked: 20 times
Post by 360gts »
steve1071 wrote: Thu Apr 08, 2021 6:29 pm
Hi Steve...they are riveted.
steve1071
Post by steve1071 »
360gts wrote: Thu Apr 08, 2021 7:18 pm
Thanks, do you have a pic of the rivet from the other side of the firewall please? For a pal of mine that’s doing a ‘65.
360gts
Post by 360gts »
[/quote]
Hi Steve,
Should have been more clearer about the brackets.
The two on the rear firewall are welded...the three along the rear are riveted.
See these pictures.
steve1071
Post by steve1071 »
Thanks again
Fanfaniracing
Post by Fanfaniracing »
gogsymac wrote: Thu Apr 08, 2021 4:02 pm I found a source for these slide in clips - or at least ones which look very similar. Can't recall where I got them but can find out if anyone needs to know.
Pics below.
Hi!
I would be interested in a pair!
Best Regards
Fabian
gogsymac
Post by gogsymac »
No problem - just send me a DM with your details and I will oblige.
