Thanks for the tip on the full panel - will talk it through with the guys at the workshop in the morning. The old saying about a ha'porth of tar is coming to mind..
Well, personally I've done nothing! This is all way beyond my skills, so I've left it people who have been doing this sort of thing for years and years. We've had a long discussion about doors.. The doors that are with the car at the moment are fairly knackered and so will require either extensive work or replacing with something else, possibly Heritage. Doesn't matter really which way as it all comes to an amount; I either spend money on bodyshop hours rebuilding these ones or go with a pair of Heritage doors (and be really picky if they're not up to scratch)woodypup59 wrote:I don't want to teach my grandma ......
But I hope you've trial fitted doors and hinges into the door hole, bolted to A panels, complete with door rubbers, while its just tacked together.
Many door apertures need a bit of squeezing with a porta-power or WHY to get the gaps right before full welding .
Some WD40, a block of wood (to support the strut), a thin, wide, cold chisel and a hammer.gs.davies wrote:Has anyone got any tips on seperating the rubber cone from the strut? These are stuck solid after however long of being installed..
Hahahaha!mk1 wrote:Or you could also try holding the strut & doughnut like a medieval mace a whacking the ground with it repeatedly until it gives up. But if you do, make sure the donught doesn't bounce off the ground & nearly remove your nose.
I won't tell you how I know this![]()
On second thoughts, use the WD40 & Cold Chisel method, it works much better.
